2007 Ultra 80,000 miles
At the end of last year I started hearing knocking coming from the front of my bike. Rough starts and under load it would slip and sound like a grinding noise. To me from research, I thought I had the compensator failure. Opened up my primary today and it appears that the last owner put in the replacement that bypasses the need for a compensator. Now I am worried what could really be the cause of the issue. Any thoughts or tests I can do to figure this out?
It could be a lot of things keep going pull the clutch and main sprocket. Was there any metal shavings on the drain plug? A noise problem is one thing but slipping with no metal shavings tells me it might be in the clutch basket. So keep going pulling the clutch basket apart isn't bad there is a series of plates steel plates then friction plates keep them in order and look for damege
