Guys, hoping you can help me out here. I have a nice '99 Road King Classic with EFI. It runs great, but has issues starting when the ambient temp is low (around 40F or colder) and also hot-start issues after a short heat soak.
In both cases, the symptoms are the same: the engine cranks, tries to fire, and dies. Upon re-crank, the engine fires and usually 'kicks back' with a puff of smoke out the air cleaner. Re-cranking again will basically cause the engine to just crank and crank without firing. Cracking the throttle open while cranking usually gets it running, but no other way.
So I've contacted Zippers, and they tell me there are two options: a full conversion which includes a new intake manifold and ECM, or just a ThundMax module which replaces the stock ECM but also includes two new O2 sensors, which I'd have to drill and weld bungs into the exhaust for.
Just the module is $899. The whole changeover is $2095.
There is also switching over to carb which is what must folks do. There are few folks out there who are any good with mm injection any more and parts are hard to come by, but they are out there. It is a pretty simple system. Sometimes a good cleaning will get it working again, always worth a try. Otherwise if ya are set on staying fi the thundermax is a good option unless ya can get a used '02-'06 setup for a dime. Good luck.
I've thought about the carb option, but even that is not cheap or simple. I think I'd have as much money into that conversion as buying the ThunderMax setup.
Obviously, EFI has advantages over carb when working properly.
Might wanna try a new engine temp sensor. Those are known to go bad over time and lead to weird symptoms. Your problem sounds temperature related, so it seems likely? Sensor is about $45 if I remember correctly.
I understand your concerns. I did the carb conversion and it is not going to cost you $900. After selling my old parts, I was only about $300 into it.
On the other hand, I wish I had a dependable FI system. If the bike is a long-time keeper, go for the upgrade. Otherwise, take the $1000 or $2000 and upgrade the whole bike. You can get the newer frame and good fuel injection and not have to worry. Except when it comes to upgrades, then you gotta Dyno it, there's another $500- $600.
With all the crap I went through with my bike this weekend, I'm thinking about just buying a new Road Glide or Low Rider S.
Or, maybe just win one!
