extra wires in the headlight housing
Hi all,
So I was adding a Headlight modulator to my bike and when I took off the headlight, there are two wires coming, one orange and white and one black with 90 degree female spade connectors. The orange wire's connector had a red plastic cap that was tapped on it.
Can anybody tell me what these wires are for?? Below is a picture of the wires. Bike is 2013 Road King Classic
Farmboy666, how did you do that? Which wires did you connect?
I bought the independent control wire harness (separate posting) to accomplish this same task but I am running into issues.
The wiring diagram looks like the orange and white wire is for the fender lamp and the black one is for a HDI position lamp (don't know what that is). Pic is below.
HDI position lamp is a little sidelight bulb in the lower part of the headlamp bucket...
I have one on my US bike in the UK
The fender tip wire has different style connectors - they are box type.
The independent control harness is for the running lamps I believe - enables them to be on when you are on high beam. If you have a halo lamp just run it off the two wires you have in your hand :-)
