Removing Dash panel adhered with double sided tape
Does anybody have any ideas on removing a Kuryakyn product adhered with the fingernail rubbed and activated double sided tape?
I had an original Harley chrome lower fairing switch cover accent on my bike that was damaged along with the black fairing cover itself while removing the ignition switch. I replaced the cover and purchased the Kuryakyn chrome piece instead of the original Harley...Big mistake. The Kury cover is total junk and now I need to remove it without damaging the cover its mounted on?
I've pried at it by hand, heated it with a heat gun as much as I dare with all the plastic around it and its not budging? I don't think I can get fishing line up in there because of all the curves etc. Any suggestions?
Thanks
Thanks
I know because I just bought this new one. I'm hoping to get it off without having to pry with any type of tool. I have interior auto panel removal tools all made of plastic but I know it will end up damaging the part if I have to pry against each piece.
If you can get some fishing line behind the tape and pull it back and forth it should cut right through. If done this with double sided tape and works pretty good. Also, dental floss will work but it keeps breaking so you'll go through a few strands.
Received 47,790 Likes
Rickr01 (05-10-2017)
