2003 harmon kardon help needed
Greetings everyone. Last fall I bought my first Harley, a 2003 ultra classic. I probably committed the classic noob blunder and bought something too old with too many miles but I fell in love with the bike at first sight. It's got a few issues and one that's got me stumped is the radio. According to what I've read you put the radio into diagnostic mode by pressing 2 soft keys. Mine goes into diagnostic mode with only holding one button down and shows a 0 in the first position, so it's like 011111. All the buttons seem to make the 0s and 1s change except the mode switch on the handlebar doesn't seem to do anything. I'm trying to eliminate the handlebar controls as a possible cause of the problems. I don't want to send the radio off to get fixed only to find the problem wasn't in the radio. Could a short in the mode switch cause a radio to become completely non functional? The radio lights up when powered up and the clock works (although I can't change the time) and thats it. No other displays, no buttons work or anything. Any troubleshooting tips you guys have would be appreciated.
If it is an 03 it isn't a harmon Kardon the radio is a Radio sound , unless someone changed it, and that could be the problem.
have you tried to plug in a phone or anything into the AUX port, and selecting aux with the hand controls?
A pic of the radio would help.
Radio sound can fix it if it is one of theirs , they are in Louisville KY.
You could ask them for troubleshooting ideas too.
customerservice@radiosound.com
How to set the clock.
2 or 2
HRS
2:
Second (2) preset button is used to store and then recall a
selected radio frequency.
HRS:
Time-of-day hours (HRS) set button. With receiver
POWER off, momentarily press the 2
HRS button to incre-
ment the hours in the time-of-day display by one. Pressing
and holding the button will cause the hours to continue to
increment until the button is released.
NOTE
The 2
HRS button is found only on the FLHTCU Ultra Classic
Electra Glide. On all other models, the HRS function uses a
separate HRS button.
3 or 3
MIN
3:
Third (3) preset button is used to store and then recall a
MIN:
Time-of-day minutes (MIN) set button. With the receiver
POWER off, momentarily press the 3
MIN button to incre-
ment the minutes in the time-of-day display by one. Pressing
and holding the button will cause the minutes to continue to
NOTE
The 3
MIN button is found only on the FLHTCU Ultra Classic
Electra Glide. On all other models, the MIN function uses a
separate MIN button.
