2000 E-glide transmission ?
Old May 23, 2017 | 10:00 PM
Y2K's Avatar
Y2K
Question 2000 E-glide transmission ?
So it looks like the trans on my 2000 FLHTC may have given up the ghost at about 190,000 miles and I'm tight on $ having just had the engine done (nice 103" build).
I see a couple of complete trannys on eBay from 1999 models for pretty cheap. I've read elsewhere that '99 and '00 are the same but when I click the eBay compatibility button it doesn't match, maybe just an eBay ad error?
What fits what? I've read that '01 and later don't bolt in without the later model primary. So are '99 and '00 the same? Might be why they are cheap as they fit 2 years only? I want to be sure the '99 will bolt in my '00 before I pull the trigger.
I'm thinking a complete used trans bolt in might be the cheapest way to get me up and running again if it'll fit.
Old May 24, 2017 | 08:19 AM
dawg's Avatar
dawg
The 99 and 00 tranny cases will only bolt up to the 99 and 00 model year inner primaries. There is a difference in the bolt pattern where the tranny bolts to the inner. Any transmission case newer than a 2000 will not fit unless you get the newer inner primary along with it. If you're just replacing gear sets and insides, then you have more options as for what years you can use.
Old May 24, 2017 | 08:29 AM
larsfum's Avatar
larsfum
Keep in mind if you put a later year gearset in the 2000 you will probably have to recalibrate the speedometer.
Old May 24, 2017 | 12:51 PM
grbrown's Avatar
grbrown
You can check compatible part numbers on-line here. That link confirms a change in casing as described by dawg, so you need a 1999/2000 tranny.
Old May 24, 2017 | 07:29 PM
s-glide76's Avatar
s-glide76
I have a 97 electra glide with 186,000 miles.
A couple months ago I was at a stop light, light turned green, let clutch out, didn't go nowhere. Clutch pull felt normal. foot shifter felt normal. I also thought the transmission went out. Tow truck took me home and I put the bike in the rear garage.
2 weeks ago I put the bike up on the lift to tear the transmission apart. Pulled primary cover off and there were a couple chewed up pins that fell out.
Turns out that the primary chain gear is riveted to the the clutch hub. The rivets wallowed out the holes and their heads pulled out. The primary chains rear sprocket was just spinning on the clutch hub.
I just received a used complete clutch assembly off of ebay today ($150). I'll have the bike back on the road Friday night.
Hope yours is an easy fix also.
Old May 24, 2017 | 10:38 PM
Y2K's Avatar
Y2K
Not the case with mine,it goes into all gears except 4th and will move but makes a chattering noise in any gear it's in when moving. No 4th gear up or down shifting,shift twice and you can pass forth up or down so it's in the tranny. No chatter in neutral at all,engine sounds great,no clutch slipping or primary chain noise.
Old May 24, 2017 | 10:40 PM
Y2K's Avatar
Y2K
Why is that? I'm looking at a gear set from a 2001 Ultra for sale. Not the same?
Old May 24, 2017 | 10:42 PM
Y2K's Avatar
Y2K
So a '99 complete should be a direct replacement for my 2000 correct?
rsscoggins
EVO
Jun 20, 2019 03:51 PM
Kozmo
EVO
21
Dec 14, 2017 05:53 PM
jwyrem
Welcome Area Only
15
Apr 26, 2011 08:05 PM
DavHJ
Dec 3, 2009 12:37 PM
mayfiebl
Apr 2, 2008 03:06 PM
