Power Vision PV-1 Data Cable Pin Out (4 Pin J1850)
Posted this in the ignition/tuner section a couple days ago and have not received a response yet so thought I'd try here.
Looking for the Power Vision PV-1 4 pin data cable pin out. In other words, the 4 pin Deutsch connector to the 8 pin PV connector pin out. If some one could grab an adult beverage, relax, then ohm out the Deutsch side of the connecto to the 8 pin connector it would be appreciated.
I found this for the PV-1 data cable on another forum and would like to confirm. Thanks!!
Top row from left to right:
12V +, CAN High, N/A, Ground
Bottom row from left to right:
J1850, CAN Low, N/A, N/A
For 4 pin aplications up to 2011 You need to connect:
12+ from PV to Grey wire on DLC socket
GND from PV to Black wire on DLC socket
J1850 from PV to Light/Green wire on DLC socket
KumaRide
05-24-2017 10:09 AM
