Denim black detailing
Picked up some of the matte detailing stuff from chemical guys. http://www.chemicalguys.com/Complete...p/hol99516.htm
Applied the Jetseal, waited 20min and removed with a light mist of the detail spray on microfiber cloth. Everything looks like stock just really clean. Time will tell how it holds up and if it helps resist the elements....
I have the flat paint on my Victory Highball, same rough texture as the Harley denim. What I found to work exceptionally well is a bucket of hot water and two microfiber cloths.
Wet the bike, dunk one cloth in the hot water and lay it flat on the surface you're cleaning, pull it straight towards you. Don't rub or swirl the cloths. Take your other dry microfiber cloth and lay it flat on the same surface, pull it straight towards you to dry it. Perfectly clean, no water spots, and practically free.
If you have a bunch of bug guts to clean, let the hot, wet cloth sit for a couple minutes. They'll slide right off.
