Oil again!
that would assume that the primary fluids you want to use are compatible and will mix or blend.
on a primary drain/fill about 5 or 8 oz of fluid will be held in the primary and clutch- part of that is absorbed into the clutch disks and you will never get that out.
so I'd suggest using same primary fluid as you use now.
Mike
Mike
