what to use to clean IAC sensor?
iac was caked with all kinds of funky stuff,aswell as the hollow area inside the tb wall were it goes into. At that point im guessen anything would have been fine to clean it with, but instead replaced it on account of its age.Ive been told all those cleaners are really a rip off and just pick up a gallon can of kerosene. MAF or MAP might be a different story but id replace that too.
Later model engines may be different but the throttle bodies I worked on in the 90's were coated with a sealant, use any form of aggressive cleaner and you remove said sealant leading to phantom vacuum leaks poor running and loss of electronic controls to the point of ECM dropping inconsistent codes or again phantoms.
If it will not clean using a soft bristle brush(think toothbrush or flossing brush) and a little water then I replace, for throttle body region at the throttle plate edge junction wipe with a water moistened rag nothing more.
