HD Electra Glo Saddle Bag Lights
I just purchased a pair of the Electra Glo LED saddle bag lights for my 15 RGS. I understand they're supposedly "plug and play" however, I haven't been able to locate a single instructional video on the install. I'm sure many of you have this set up and would appreciate some feedback on the best method of installation.
for the older version ( like my 09) the lights plug into the accessory plug using the run, brake and ground pins-
(the acc pin is unused and can be accessed by inserting pin into the block if you add something later)
i think on your model the acc plug is under the left side cover
mine came with instructions-
I drilled a small hole in the saddlebag, de-pinned the wires from the connector block, passed the wires through the hole, reinserted the pins and plugged into the Y cable which is plugged into the acc plug
Mike
Mike
Mike
Mike
