Letter from HD - Important Brake Maintenance Information
#41
http://www.harley-davidson.com/conte...y-service.html
Now, everyone can say they received the letter. Make it into a poster, frame it and hang it in your garage!
#42
Given the responses in this thread, its appears only abs equipped bikes were sent a letter about Brake Fluid Maintenance. I say, this letter is a futile and very late attempt at a cya and the NHTSA investigation. Or, maybe this is the outcome of the investigation?
Also, the supplier of the abs system is BWI. Beijing West Industries. I called and left a message at the US, Ohio location. Hopefully they are responsive and return the call. I specifically want to know about the design, or lack of, for a fail safe circuit when one of the plungers locks up and prohibits brake fluid flowing to a caliper. And, if their was ever a change or revision to the abs hcu. Only one hd part number is listed and can be ordered, no revisions.
http://www.bwigroup.com/product/two-wheel-abs/
Rushmores are advertised as having Bosch.
#43
#44
I bought my 2011 FLHX used on February 11th and my wife received the letter. We are both on the title but the letter was addressed only to her.
Reckon the MoCo figgered she'd take it pretty seriously. Ironically, it came a few days before I had that weekend chore scheduled!
Good idea to get it serviced or check service records to verify last service.
#45
#46
No ABS bike here, and of course no letter either, but I have experienced 2 instances of the front master cylinder failing and drawing air due to corrosion in the cylinder from deteriorated and contaminated DOT 4 fluid. And this was after always doing the 2 year fluid flush. I now do it yearly, both front and rear. Although the front is where the problem has been.
I don't know why Harley's have so much brake fluid problem and cars and trucks do not. Its possible cars have a sealed system and we do not, but I don't know that for sure. I put in Speed Bleeders to make the job simple and painless. I would recommend that to everyone.
http://speedbleeder.com/
#47
#48
Thats a question for MoCo. No doubt they have looked into it. Given the letters recently mailed to thousands of abs owners of bikes that are up to 9 years old, HD's position is the hcu fails due to fluid not serviced every two years. And thats all fine, although not typical of other abs systems. The issue I have is HD advertises a fail safe abs system that will resume to normal, non-abs, braking when the abs fails. That statement and advertisement is proven to be 100% false.
#49
Dave61 (02-09-2020)
#50
https://www-odi.nhtsa.dot.gov/downlo...42017-1234.pdf
You will notice that the Preliminary Evaluation (PE) for the ABS defect began on 06-July-2016. According to this document, this issue should have been resolved already.
Initial phase of a NHTSA investigation, a PE is prompted after a review of consumer complaints and/or manufacturer service bulletins suggest a safety defect may exist. The results of a PE determine whether the investigation will be upgraded to an Engineering Analysis or closed. Most PEs are resolved within four months.
Edit - Added ODI Resume document
