Battery Melt Down
Old Jul 17, 2017 | 07:18 PM
2013_FLHTK's Avatar
2013_FLHTK
Default Battery Melt Down
Anyone ever see this before. The negative terminal on a friends Road King just melted. Funny thing is it still works. He ordered a Deka today.
Old Jul 17, 2017 | 07:20 PM
TwiZted Biker's Avatar
TwiZted Biker
Loose cable will do that, I use star or serrated washers on all my cable connections just because of that.
Old Jul 17, 2017 | 07:22 PM
dawg's Avatar
dawg
Make sure there isn't a dead short that caused it to melt. That will do it also.
Old Jul 17, 2017 | 07:41 PM
mkguitar's Avatar
mkguitar
loose connection- check BOTH ends.
check the cables are not rotted inside the insulation too
mike
Old Jul 17, 2017 | 08:33 PM
ORradtech's Avatar
ORradtech
Probably what they said.
But a connection that bad should have given other symptoms. Hard start, flickering lights, dim lights maybe even rough running.
have you checked for codes? Measured voltage at the battery with the bike running?
Old Jul 18, 2017 | 04:30 AM
2013_FLHTK's Avatar
2013_FLHTK
The owner also thinks it was a loose connection. He has had problems in the past with the negative side not staying tight. Luckily he had enough tools with him to get it tight enough to get him home.
Old Jul 18, 2017 | 12:08 PM
Alter Kaker's Avatar
Alter Kaker
Senior Rider
Default Battery
I just replaced my battery a few weeks ago.
EVERY threaded connection got blue locktite!
Old Jul 18, 2017 | 12:37 PM
hardheaded's Avatar
hardheaded
make sure all your grounds are good to start , then every connection on the bike. make sure you are not over charging too !
mlrailguy
Aug 29, 2017 12:12 PM
yinyang0024
Apr 19, 2017 07:25 PM
Lawdog1118
Apr 3, 2011 11:53 AM
Mr. Scratch
Sep 11, 2010 10:05 AM
jd140400
Nov 17, 2008 05:08 PM
