swapping lock cylinder out
I would like to remove the lock cylinder so I can put it in a new ignition switch. Mine has the floppy cover syndrome; the spring thingy that keeps the cover latched is gone so it flops in the wind. I'd like to get a new ignition switch, but put the lock barrel from the old ignition switch in the new switch so I don't have to rekey my fork lock and bags, or vice versa. Is this doable? The guy at the dealer said it's a non-serviceable unit and I'd have to buy a new ignition switch ($200) and then get my fork lock and bags rekeyed to match, or other way around. I read a thread where someone accidentally pulled the lock barrel out, so just seeing if it's doable without tearing up a new ignition switch, thanks.
I wanted to switch out my ignition on my road king because I was turning all chrome black. I ordered a black ignition switch online. Plan was to disassemble and put the old barrel lock into the black ignition switch to retain the same key. Although fairly simple to do it didn't end up working for me because the electrical connector on the bottom of the ignition switch was slightly different from the original one preventing the wire harness from connecting properly. Removing the barrel lock is as simple as using spring clip pliers to remove the clip and then carefully taking it apart making sure to note orientation of the little springs inside and then putting it back together the same way.
well, I got it completely apart (almost); I couldn't get the barrel to drop out; I looks like there is a small allen head screw that may hold it in, but you'd need a extremely small allen wrench with a super short neck to get to it; unless I am missing something, that's the only way that I could see it coming out
