Tire pressure Gauge variances - what gauge is best
Just put a new rear tire on due to horrible cupping, and some state tire pressure could be the culprit. Avon Reccomends 44 PSI for the Cobra I installed.
I have 3 different gauges, and all 3 show a different reading. - no idea which one (if any) are correct. They are all around 2-3 PSI different. I took the middle reading to set my pressure.
So. . . . Will +/-3 PSI make a notable difference? If so, What is the most accurate gauge that will get in the tight space for the rear valve.
The following 2 users liked this post by CSS899:
Peter Griffin (09-18-2017),
twoglides13 (09-19-2017)
This link might be somewhat helpful: http://www.mcnews.com/mcn/technical/200511gauges.pdf
I use this pressure gauge based on recommendations from forum members in a previous thread on the subject.
http://www.amazon.com/Joes-Racing-32.../dp/B003TQ2W44
I was quite disappointed to find out it's 12 years old. Has anyone checked to see if any of the reccomended guages are still available?
FWIW Consumer Reports has done a more recent comparison with their reccomendations available on Amazon.
Gauges vary, I don't trust the pencil or stick type of gauge, get a dial type of gauge.
You may want one with a flexible hose, it is easier to get to the valve steam & read.
If you have an air compressor, get an air compressor chuck with a dial gauge, amazon
sale good ones. That being said, use the same air gauge every time you check the air
in your tires, it will be more consistent. I have a hand held, and a compressor type from
the same manufacture for consistency. The important think is to check the air in your
tires at least once a month, and befor you go on a trip for sure.
John
John
