Aftermarket tourpak lights
I've got a 2013 Eglide Classic. The only lights on the back end are the tail light and the signals, both located low on the bike. I'm looking for something that will mount on the back of the trunk, preferably with integrated signal lights. There is a harness in the trunk with a vacant connector that could be a light connection. If this is so then plug and play would be ideal but I'm not above having to wire it directly. I've found a few on the net but so far I'm not impressed. Has anyone found something like this that they are happy with?
Tour Pak Lighting
I had these on my 2011 RGU and they made the bike much more visible.
They come in one long light or divided in center light with turn signals. All are operable when braking and using the turn signals.
https://www.harley-davidson.com/stor...CatEntryType=2
Used two custom dynamic truflex led strips. They look small but are easily seen, very bright intense light, and have lifetime warranty. Wired to existing rtb module so they are turns, brake and running lights. Used a connector so can remove tp easily.
09IronRider
Milwaukee Eight (M8)
12-27-2018 12:34 PM
