90 degree Tire Valve extension
If that screws directly onto an existing, rubber valve stem, I would be very leery about using it. The additional inertia while riding may cause the rubber stem to flex unnaturally, leading to fracture and failure. I had tire pressure monitoring stems which caused that to happen. Just a heads up.
You could use the one's that Fobo sells even if you do not want to use the FoBo pressure unit.
https://my-fobo.com/Product/FOBOACCS
Been running these for a few months with the pressure monitors. Much easier to fill now. My indie installed when I put new rubber on prior to Sturgis, he did say the washers didn't work too well and he used different ones instead.
This has worked for me and a buddy. He has a '12 King with those knuckle wheels and I a Softail Deluxe.
https://www.harley-davidson.com/stor...stem-extension
If your going to do it, do it right.
You install these valve stems at the time of tire replacement.
Complete valve stem replacements, not extensions.
https://www.kurveygirl.com/shop/prod...nlrj4j89slfbu7
