S & S Teardrop on my FLHRCi
andypocock (12-11-2017)
Thanks Harkon. I think you are right. Found an old listing for one for the MM EFI but nothing recent. Probably not enough of us around to make it worthwhile.
Thanks for the photo of the backplate. Very helpful. Might be that I can coax an S&S teardrop cover onto that. If not I'll adapt the foam and mesh filter I had on my Dyna. I can't get on with all this modern stuff the catalogues are full of. Too old.
Andy
Andy
With that FI system, you'd need a double cone or something for it too work as intended. Which probably would not work as, I am guessing, the two would reduce the effect of each other and would change the look.
Is it just the classic looks, and the S&S logo, or performance you are after?
If performance, a K&N or something filter in there would pretty much do as much or find something designed to fit.
Or buy a carb kit (which is going to be expensive).
I'm guess why this is why it's not listed.
Bluehighways
01-18-2019 08:23 PM
