2008 Road King CVO wanders on freeway rain grooves. Advice?
Here’s a novel idea! Put in the tire pressure recommended by Harley. That accounts for weight and geometry, and creates the proper contact patch. Higher pressure reduces the contact patch, which increases the tendency to track grooves.
BTW, my ‘17 Road King with stock Dunlops, and 3,600 miles, tracks straight as an arrow on Southern California freeways...even at high speed. Except for a few of the joints that seem wide enough to swallow an entire tire...
Edit: But, on the other hand, my TriGlide with Michele CIIs seem to track grooves at times.
Hey there. I have a 2008 Road King CVO and has Pirelli Night Dragons on it which handled great in the mountains but on the California freeway the front wheel really wanders. I just put on some Avon's today (AV65 and AV71) and jumped on the freeway and it's still the same. The stock tires didn't seem to be as bad...but I'm wondering if I'm missing something?
It's pretty bad. The Avon's haven't broken in yet but I don't know if it will change.
Thanks in advance!!!
The stock Dunlops to track nice in the straight line on the highway, but those other tires ought to be okay too.
Just some possible items that might affect the handling.
It seems the stock tires didn't do it as much. Put on the Pirelli's and it handled much better in the mountains but the "freeway wander" showed up. Elite 3's are somewhat new, right?
I've got the same bike riding on the stock Dunlops. It does ok with rain grooves and any lines in the road except for tar snakes...certain ones make it feel like I'm riding on marbles. Maybe check steering head bearing and swing arm bushings,also check to the wheels to see if they're aligned. Good luck
Did you ever try other tires? Thanks for responding!
Avon has their own recommendation as far as inflation goes. Do not use the HD spec with Avon’s
www.avonmoto.com
www.avonmoto.com
