cam swap vs. 103 w/cams
decisions, decisions, decisions....have a post on here about doing a cam swap on my 09 roadie with 12000 miles. i have researched everything and will most likely go with tw555 cams, new bearings , and adj. push rods. cost will be about 650.00 with me doing the labor. (includes a few tools also).
my questions is how much more would it cost me to go ahead and install a 103 kit, keeping in mine i would have to pay for the parts and labor going this route. also, i would most likely just go ahead and have cam work done at the same time.
bottom line::::
1. cost of 103 kit with cam
2. labor cost
3. most important...name of a good wrench in houston texas area..
thanks
bottom line::::
2. labor cost
thanks
Why is it that you are OK with labor on the cam swap but choke on the 103 kit? Do the whole thing, bore your cylinders for $120-$130 and buy new cast flat top pistons for $175 (less 20% if from a discount dealer like Zanottis), gaskets, oil and your done. While you have the heads off, spend the money you saved on labor on a Big Boyz "street" port job for $299 plus a little more to deck for compression. No additional tools required but you will need a service manual. Don't think about it, just do it.
+1 I'd say the cam change is more difficult than the BB & if you do a little research you can use "perfect length" non- adjustable pushrods to save a little $. I'd go with a 107 kit, the cost is very little if any more & you get more bang for the $. I've done the top end several times with no problem, luckily I've got a buddy with the tools for doing cams, so it's cheaper to give him a few $ than to buy the tools myself.
