Brake Bleed
No problem with the mix of DOT 4's, but this will keep it at a minimum:
Using a cheap turkey baster, remove all brake fluid from the reservoir, refill with the new type fluid. THEN Mity vac fluid down and out the bleeders, keep filling the master with the new type fluid as to not run out of fluid. When new fluid is all thru the system, proceed to the other and repeat. Same way with speed bleeders.
I always start my bleeding procedure this way, it is more effective in less time.
Otherwise, many folks just move old fluid down the line, and put new fluid in the reservoir.
Think about it...
Think about it...
Received 2,524 Likes
With the Bikemaster bleeder I just vacuum it right out of the master cylinder, then refill with new fluid, hook the lines to the bleeders and vacuum again until I see new fluid......top up and done.
Specs are all DOT 4 fluids are to be mixable without problem. I know of no instance where that wasn't the case.
We have several bleeders at the shop, bikemaster is one of them which we replace once in while. Another is the Mityvac, Part No: MV6830. We've never replaced the Mityvac, just new hoses once in while. The Mityvac beats all others hands down, it'll pull a golf ball through a garden hose. You actually have to be careful how much you open the bleeder valve or it will pull too much. I've never had a problem with air being retained in the line or joints with the Mityvac.
hitthecoast
12-24-2017 09:23 PM
