Finally Getting Around to Baker Compensator
#52
#53
thanks,
Steve
#54
Rock Chalk (03-18-2018)
#55
There is about .35" from the nose of the main shaft to the snap ring holding the needle bearing in place (see picture) That seal is not that thick. The seal driver I use to install that seal sets the seal about .035 below the nose of the main shaft. (see pic). You should be fine unless your really drove that seal home and deformed it against that snap ring
#57
No, didn't get back around to it after I had a couple "you should be ok's". Hope to get back to it this weekend (too many track meets and practices before then...).
Need to make sure I've got the right sized gauge to make sure i get the race installed to the instructions.
Would you recommend using red Loctite as mentioned by some for the race?
Thanks,
Steve
Thanks,
Steve
#58
#59
#60
