Looking for some advice/points of view
First of all, thanks for taking the time to read this. I have a 2005 RK Police with 55kmiles on it.
All of a sudden she started to leak oil from the primary a couple of months ago. I went to rumbleon and they low balled me, way too much. I was sincere when entered the information for getting a quote.
This bike won’t probably be a garage queen but she runs strong and here’s where I’m start having a ton of questions; I don’t want to keep her as she is know, mostly stock (except for the pipes) but I don’t want to invest money on doing improvements on an old bike, I will have to change tires, front suspension, brakes and do the transmission at minimum.
I know I should be able to come up with my own decisions but any point of view, opinions, suggestions would be much appreciated,
Thanks again for your time and enjoy the weekend
jp82
jp82
Time for a new bike, and it will cost you. Interesting that you thought they low balled you and yet you listed a ton of issues with the bike. Somebody is going to have to pay for those issues - tires, leaks, etc. Several options, 1) fix the bike yourself and trade at the dealer or 2) fix the bike yourself and private sale, which will probably yield more money than the dealer, but you still need to be realistic. 3) trade at the dealer as is 4) private sale as is.
Motorcycling is an expensive hobby.
Ask yourself what you really want out of a motorcycle. Then you need to figure out two things.
First, what does your current bike need to entice you to keep it, and how much would that cost?
Second, how much would it cost to buy the bike that already has what you want? (Minus the trade-in value of the current bike).
Once you have those nailed down you won't need our opinions.
GM
GM
If it is the stator plug a good cleaning and degreasing and judicious application of black silicone gasket maker will seal the leak just fine. No need to spend hundreds of dollars changing a working stator.
All the things you mentioned that need to be done are regular maintenance anyways, and I hope you've done those at least once! Dealer isn't going to give you much for your bike, because they have to replace those items that you don't want to spend money on.
I'm not sure I understand your dilemma: I'm guessing you (a) want to trade your bike in for new, (b) want to trade and upgrade to a newer/used model, or (c) want to fix your existing bike. Only you know your financial situation and the love for your bike. If you have $30k for new, trade your bike in and go for it. If not, put $1-2k into your bike and enjoy it. Find a good mechanic and knock it out.
If you look to selling it either fix it up correctly or please disclose all that is wrong with it when you list it there are a bunch of us that don't mind wrenching on a good deal but we need to know the problem up front. If you know how to repair it please do so then sell would not recommend the dealer for repair that's way too expensive. If you can't do the repairs I would recommend selling at a discount through cl and replace it with a newer one
