Key Fob / Security ????
Morning fellow riders, i recently purchased a 2002 Electra Glide. The issue I'm running into is that I can start my bike no problem without the key fob by or near the bike or without it asking for a Pin... Anybody have any idea why that is? I have the red Key display on the gauge plus the blinkers blink a couple times then goes away. Any help would be great.
No I don't have w key hiding on the bike..
Factory alarm on a 2002 is a push button arm/disarm, not a proximity fob.
If if you have the owners manual (or get it @ Harley website for free) you can see how to “auto arm” after 30 seconds or so. This would require you to disarm it before starting, and it would arm itself after shut down.
It has the dog with the button in the middle when I hold it for 2-3 seconds the light flashes and if I try to start to the bike it won't and the four ways come on..
So should I take this is for services? I looked for the owners manual and it doesn't really dive into the whole red Key light on the gauge. I have downloaded it from Harley.
If the four ways come after holding the button on the fob and you cannot start the bike, you have set the alarm. Hold the button again and it should undo the alarm and the bike should start.
If this is what is happening, you have the optional security system in place. Your fob button requires you to set the alarm and undo the alarm manually unlike the proximity fobs.
It sounds like the alarm sets as designed (highlighted above)
Once alarm is set, you hit the button 2x, the turn signals flash once, and the bike is supposed to start....
If so, you're security is working as designed....
Then the red key is notification of another issue(s). You'll need to access the codes, kind of a pain on an 2002
If you don't want to research the issue online, you need to pick up an electrical diagnostic manual (good to get the service manual & parts manual too) for your bike.
to arm the alarm the alarm manually: press and hold the button on the fob until the turn signal lights on dash flash. Note, factory alarm systems from harley did not always come with a siren, the flashing of the dash lights and turn signals is the only indication you will receive that alarm has been set.
When alarm is set, the red key in speedo will flash slowly.
To disarm the alatm, press the button on the fob, two times in quick succession. The turn signals and dash lights will flash, and the red key in speedo will not be illuminated. Again, no siren, so you will not receive an audible confirmation.
it sounds like the alarm is working as designed. It is different than a car alarm, and that can sometimes trip new users up.
when you try to start the bike with the alarm set (or roll it, or stand it up, or turn the bars) the lights will flash. This is the alarm going “off”. Without the siren, it is just flashing light. If it were a car, the horn and siren would be going off in addition to the lights flashing.
Hioe that clears things ip for you.
Good luck.
Oh ok sure did the owner before me had the bike from the beginning, kept telling me it's a prox fob.. So it's only the fob to arm/disarm my security system. So technically I need the circle key to lock or unlock my ignition switch.. Solves the problem. lol The whole time I was thinking it was a prox-fob. lol
As per the reply regarding the codes. I've checked the code banks 1 through 10 and found nothing. That was fun finding out how to do that. Next I will be changing my 5 digit pin just if I forget a fob when the secuirty system is aet.
