Unfamiliar Sound
Unfamiliar Sound
I’m new to HD, having come over from a 02 Honda gl1800 to a 13 ultra limited. I’m getting used to the sounds of the HD, however, I’m hearing a sound that puzzles me. When rocking the throttle, I’m hearing a “Klink” just prior to accelerating and decelerating torque. It happens regardless of rpm or gear.
A couple of seasonedHD riders have told me that’s normal, nothing to worry about. However, a friend I was riding with this morning, on his 16 RG CVO, said his does not make that sound.
Has anyone else experienced this, and is it indeed normal? I’m a little Leary of unfamiliar sounds as the wing I rode was tight and quiet.
wadescar (05-19-2018)
Welcome to the wonderful world of Harley. I too am a former Goldwing jockey. It took me a while to get used to all the funky Harley noises. I wouldn’t want to try to diagnose yours based on the description you gave. Could be the compensator. Could be something else entirely. Hard to tell without tearing into it. If it worries you that much take it to a competent tech and have them listen to it. Otherwise just ride the crap out of it til it breaks, fix it and ride it some more. If it really is the compensator it’ll get a whole lot worse before it fails. You should start hearing a loud clank when you shut it down and it’ll start giving trouble when you start it up. Not all that complicated to replace it. Just labor intensive and time consuming.
I believe Ripsaw answered it in another thread:
I did and he was spot on. I can’t seem to get the diagrammatic breakdown of the tranny to load, but now I’m comfortable that it’s common.
It's the drive dog rings where they engage in the gear in the transmission. The gears are always in mesh with only .002-.003 backlash but the dogs have quite a bit of lateral play.
If you jack it up and in gear, rotate the wheel back and forth, it's about 1 1/2" of play.
Item 17 in the attachment.
Dave Beckner
07-05-2018 08:04 AM
