How hard is it to install cams?
Originally Posted by Jshopes
Its not a bad job, but the cams wont just fall out of the support plate. There are tricks to that but the most common is to press the cams in amd out of it.
Campy Roadie (05-24-2018)
You shouldn't have any problems at all with your car mechanic skills. Here's good write up a member did that ended up inspiring me to do mine myself.
https://www.hdforums.com/forum/touri...-write-up.html
SCGamecock (05-22-2018)
Look at the videos and see if you think you can do it, I did and I thought I could do it, and I did... really wasn’t that complicated... I have a manual, watch the videos, rented a blind hole puller, just tapped in the new cams with a seal installation tool. Rode it for another 40000 miles. I would do it again.
This is a good thread. I have a set of SE 255's in my basement, waiting to go on my 07 Road King. Probably a next winter project. Picked them because they were a little more aggressive than stock and they bolt on with no other changes. Probably get the kit from FM when I'm ready to go. And I'll be sure to check tensioners (although they should be ok in my 07).
