Best Fork Springs For ElectraGlide?
And me! You're quite right. The MoCo has occasionally sold bikes with decent suspension, such as my 2003 FXDXT, which had fully adjustable suspension front and rear, as does my Firebolt, but I don't know of any of the touring range being so fitted. At the very least the CVO models should have the best suspension available, bar none.
The "best" fork springs are going to be the springs with the correct spring rate for your weight, regardless of what brand of spring you use.
And as others have pointed out, damping is an important component of suspension operation also. The Ohlins cartridges or something like that might be a good way to approach that.
