06 Road King charging problem
Getting 18vac out of stators at idle. On second non-OEM voltage regulator to no avail. Battery is chked good and has 12.6 V. Ground is good and tight.
Is there something between the VR and the battery that I can check?? |
Welcome to the forum from Texas. Electrical issues can be a bear and it is best to diagnose the problem in a systematic way.
There is an Electrical Subforum that has "Sticky" threads. Sticky's are permanent threads located at the top of a forum. The electrical subforum has two Sticky's on checking the charging system. Here are the links: Charging System Testing 1 Charging System Testing 2 Boog |
Thanks, BD. I'll check it out!
I read those, one earlier. Some say 17-20vac per 1000 rpm, but others say there should be 26+ at idle, then that. Confusing. Will do resistance checks tomorrow. Newbie's gotta learn! |
2006 Touring Service manual says-
AC OUTPUT CHECK 1. See Figure 1-17. To test AC output: 2. Disconnect stator from voltage regulator. a. Connect an AC voltmeter across any two stator connector socket combinations. b. Run the engine at 2000 rpm. The AC voltage output should be greater than 30-40 volts AC. c. Repeat AC voltage test across the other two stator socket combinations. 3. If the output is below specifications, charging problem could be a faulty rotor or stator. Replace the rotor or stator. 4. Check the output again as described under CURRENT OUTPUT TEST given earlier. Open Stator 1. Turn ignition keyswitch OFF. 2. Using ohmmeter probe, test for electrical continuity between all three stator connector socket combinations, that is, 1-2, 2-3, 1-3. a. See Figure 1-16. b. Resistance across all three stator socket combinations should be less than 1 ohm (typically 0.1-0.3 ohms). c. If resistance is greater than 1 ohm, then stator is OPEN and must be replaced. Grounded Stator 1. Turn ignition keyswitch OFF. 2. Connect ohmmeter as follows: a. Disconnect stator from voltage regulator. b. Insert ohmmeter probe into one of the three stator connector sockets. See Figure 1-15. c. Attach the other ohmmeter probe to a suitable ground point on the engine. Check several places to ensure good continuity is made. 3. Test for continuity between all three stator connector sockets and the ground point with ohmmeter. a. A GOOD stator will show a large resistance to ground (infinite ohms) between stator socket and ground. b. A BAD stator will show continuity between stator socket and ground. 4. Replace stator if grounded (BAD). |
I have 20, 200, 20k, 200k & 2000k ohms on the multimeter....which do I use??
Originally Posted by tomcat41142
(Post 17425939)
© 2024 MH Sub I, LLC dba Internet Brands
