Rear turn signal lenses. Need to dial it down.
Have custom dynamics rear LED's turn signals. All around really. But in the rear they are really bright. When I apply the brakes they get even brighter. I think it's because I used red lens with red leds. Question is how can I mellow the light a bit. What color lens might do that. I just added the tour pak rack brake light to make it more distinguishable. But would like to make the rear brake/running lights softer? I am think the right lens would do the trick. Thanks
they make smoke vinyl tint you can install they have it in different shades from light to dark it will take the brightness down a little (light) or a lot (dark) local shops that do car graphics can do it for you or if your handy can order some online an diy
your signal lights look like there on brake in that pic compared to your other running lights that would drive me insane if it was my bike, id swap them all to led to have the same brightness
Thanks I will think about it I agree. More light more better. But the reason for concern is my buddy said that the brake light is not that MUCH brighter. So a person can see the light. But if they can't see or tell the brake light is on. Defeats the purpose. Which is the reason for the high tail light brake light. Plus I thing the whole lights thing looks cool! lol. Check out the front of my bike . I am defiantly seen. LED's below windshield. Engine guard lights, Daymakers all around. And the Halo blinkers from Custom Dynamics. Also have the pigtail add on that allows brights and spots and the same time.
I would call Custom Dynamics and ask the why there is so little difference between running and brake. I converted my 2012 rears to CD LED's with red lenses and there is a noticeable difference between brake and running. Did you use the 1157 replacements or 1156? There is a difference and more voltage (brake) to an 1156 will make a slight difference. Could be you got the wrong LED.
The bike looks great from the front BTW.
This circuit costs ~$4 to make and works perfect. Made one a few years ago and I think used a 33 ohm resistor. Definitely used schottky diodes which have a very small forward votage drop. If you go this route, when trying different electrical components, keep in mind that the leds get brighter when the bike is actually running. Or, just spend the money with a plug and play module that can be adjusted . Either way, your buds will appreciate it.
Budda109 (07-12-2018)
