slight wobble around 70mph?
Tire pressure is set to 34psi cold
I’m going to order the rear bushing and engine front engine mount regardless just do to there age, I’ll have a look at the front steering bearing
this was happening while going straight, it’s possable it was the roads but it done it on a few different routes we was on that’s what got me wondering if it something with the bike?
again it wasn’t really bad it was pretty mild but enough to feel it, I was on it today and felt it again on another highway right about 70mph feels like the back is wondering just a touch
stroker87 (07-20-2018)
I also agree that your tire pressure is too low. What tires do you have on the bike? Go to their website and see what the recommended tire pressure is. Dunlop for example even has recommended tire pressures that are tire model and bike model specific. Don't use the pressure on the sidewall or the manual. That is max pressure for the tire and will be a lot higher than the recommended and the owners manual will be for the original tires, probably Dunlop 402's.
For example Dunlop American Elites for my bike the recommended air pressure is 36 front, 40 rear. At 34 it's going to ride different than it should.
Put the right air pressure in the tires and I bet your problem goes away. As I said before, probably no need to change those other parts unless you just want peace of mind and have extra cash and time.
i have continental conti legend's on the bike, just read the side wall 40psi max on both, there website or any place on the inner web i cant find a "recommended" pressure? i'll bump them up to 37 or 38psi i ride solo and took the tour pak off so max might be a little much i think?
i dont usually just throw parts at something hoping to fix a problem, but replacing the rubber bushing and front engine mount would make me feel better just knowing i replaced the 10+ year old parts, ill be doing the labor so its not going to hurt my pocket all that much i got a service manual to so shouldn't be to bad on me
all the feed back is awesome guys!
are bikes are getting old , I look at it like you have to stay up on there issues,and I wouldnt know what to do with all my time(retired)lol . one thing that helped was 10 years ago I added one of those tru-tracks. I also plan on doing an alignment...watched a bunch of videos , really like the simple one with the string and cones. neck and swing are bearings are on my list too perhaps
If you're particularly heavy also consider adding extra air, after trying stock pressures first. Make changes in small steps. I've owned Harleys for over 40 years and the MoCo has never addressed tyre pressures properly IMHO. A very light rider should try slightly lower pressures, just as a heavy solo rider should add a little extra, as should two riders, especially when loaded up for that grand tour. I have three sets of pressures for my Glide: solo, duo, max.
