Made a stupid error I think so have a brake question
It did sound like one piston moved out too far.
I've worked on plenty of disc brake calipers but not on a Harley unit. Pushing it in now may lodge some dirt in the bore.
If it was me I'd disconnect the line and keep it positioned upward so no air moves into the line. Disassemble the caliper and look around.
That's the plan on Sunday I think. I got the pads off now and for some reason neither of the pistons on the inside side of the caliper want to compress at all. Outside pistons slid in easily. May have found something that was already an issue and I just didn't know it yet because I've put a good amount of force behind trying to get them to compress and they will not budge.
Thanks,
Thanks,
Since you mentioned it’s s 2015 with ABS, do not cycle your ignition on. You could have gotten some air in the caliper through the spot the brake fluid was coming out of. If it hasn’t happened yet, it will when you start working more on the caliper, especially with a rebuild.
When you turn your ignition on, the ABS self cycles as a diagnostic, to make sure it’s working. You don’t want to this to happen with air in the line. Bleed before turning the bike back on.
I guess I misjudged the picture that you post with the caliper in your hand. I thought you had already taken it off and over to a wooden workbench. Forget the part where I told you to push compressed air into the brake line port......... that would be dumb, lol!
Good info on the ABS system! Thanks!
I’ve worked on motorcycle brakes more times than I can remember. For the future now I suppose, this thing has been way over complicated. 1) Always, I repeat always, loosen the master cylinder cap before compressing the brake pistons inward to relieve the back pressure. Failure to do so can over pressure the system, blow a seal, and cause leaks. Hopefully not, but if fluid is coming from where it’s not supposed to my guess is you’ve experienced this. The system isn’t designed to compensate for reverse pressure. 2) Do not pry with a screw driver or other implement because you run the risk of slipping and gouging something, and you don’t have a good feel for how much pressure you’re applying. Forcefully prying something on a brake system until it gives is always a bad idea especially if the master cylinder cap is still on. If the pistons don’t move freely something is wrong. Go to your local auto parts store and for about $10 buy a set of reverse snap ring pliers. You can buy a special tool for more money, but these work fine. They fit between the brake pads and push them apart without having to pry anything. Plus you can tell if you’re having to use undue force and stop before it gets really expensive.
Flinter (07-21-2018)
There is some good information, and some bad information above for correcting your brake problem. Please get someone that is experienced to help you with this repair. Brakes are not something to take lightly, and it will be too late if you're flying down the road and the brakes don't work when you need them most.
