Issue with start! Weird noise! Video Attached
Old 07-21-2018, 10:23 AM
pikeysxtcob's Avatar
pikeysxtcob
pikeysxtcob is offline
Exclamation Issue with start! Weird noise! Video Attached
Just finished putting cams, adjustable push rods, chain drive, and a new primary chain adjuster. Bike ran just fine for a few hours then all of sudden this is what its doing. Video attached. Im stumped on this one.
Bike is a 2015 roadglide 103
File Type: mov
Old 07-21-2018, 10:27 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,510 Likes on 3,769 Posts
Battery.. check voltage when you hit switch. Is it above 9.8 volt DC
Old 07-21-2018, 02:35 PM
stroker87's Avatar
stroker87
stroker87 is offline
starter loose? sounds like the starter is getting jammed maybe?
Old 07-21-2018, 03:23 PM
Jackie Paper
If the battery is good, I would put it in 5 gear and bump bike on concrete to make sure motor is not locked up.
Just out of curiosity, why would you put a chain drive on a maintenance free belt drive?
Old 07-21-2018, 03:30 PM
Mozvader's Avatar
Mozvader
Mozvader is offline
Received 1,184 Likes on 849 Posts
Sounds like the fuel pump is having a hard time priming.
Old 07-21-2018, 03:36 PM
Mozvader's Avatar
Mozvader
Mozvader is offline
Check the fuel filter, the internal hose, and pressure regulator. The pump sounds like it's struggling to prime but at least it's running so I doubt it has anything to do with the relay.
Old 07-21-2018, 04:05 PM
stroker87's Avatar
stroker87
if thats a relay cycling its the loudest one ive ever herd?
Old 07-21-2018, 04:15 PM
Mozvader's Avatar
Mozvader
Mozvader is offline
Is he hitting the engine start button? I thought it was the fuel pump struggling to prime.
I can't tell what he's doing with his hands in the video.
Old 07-21-2018, 05:43 PM
stroker87's Avatar
stroker87
he IS pushing the start button when you hear that thump, the pump to me sounds just fine i get the impression its the starter hard to say for sure with out being there though
id have some one hit the start button and try to hunt down where its coming from id start with my hand on the stater
Old 07-21-2018, 05:50 PM
Mozvader's Avatar
Mozvader
Mozvader is offline
That being the case I think your right. I didn't hear a thump but then again I'm following from my iPhone. Would the pressure regulator keep the bike from starting if it weren't able to prime up?
Quick Reply: Issue with start! Weird noise! Video Attached
