Fuel spraying inside gas tank
08-07-2018, 04:53 PM
I have a 2008 Road King Fuel injected. When I open the gas cap and look inside then turn on the ignition I see fuel spraying around in there. Is this normal or do I have a fuel leak inside the tank? I'm asking because I get coughing and exhaust popping when my bike heats up.
08-07-2018, 05:21 PM
You shouldn't see any gas spraying around in there. Sounds like you have a leak.
08-07-2018, 05:31 PM
common on 08 fuel pump housing, fuel lines rub through as well.
08-07-2018, 05:35 PM
d_slat Sheboygan. Your right up the road from me. Thanks. I've also heard that the spraying is a pressure release to keep the correct fuel pressure. Could that be true?
08-07-2018, 05:38 PM
wouldn't that be the pressure relief bleeding off excessive fuel?
08-07-2018, 05:51 PM
Is the spray constant ? That would Not be right ..
08-07-2018, 05:56 PM
Spray is constant while running
08-07-2018, 06:13 PM
You’ve got a pin hole in the line from the fuel pump to the throttle body. Fairly common problem a few years back.
08-07-2018, 06:19 PM
Replace the line and consider replacing the filter..if I recall correctly, the fuel filter kit contains the hose
08-07-2018, 06:34 PM
yep, sounds like pinhole in the fuel line as IronAss pointed out, pretty common apparently.
