DIY Tire Mounting
#71
#72
I have the NoMar Classic with the pedestal mount and the hitch mount. I also have their balancer. I use dyna beads on tubed tires and wheel weights on tubeless. The biggest benefit is convenience. I changed a tire last night ... when all the HD dealers and indies were home eating supper and getting ready for bed. It doesn't take long for it to pay for itself if that's a priority for you. Like one fella said, the beer fridge stays stocked with all the donations from helping out friends. The balancer also doubles as a truing stand for relacing spoked wheels.
#73
Does it actually come with the right size center pole? I got a HF one with m/c attachment and the center pole is way larger than my bearings - I'll modify it, haven't even mounted it to the floor yet.
#75
#76
Was able to pick up a lightly used HF changer w/ the motorcycle attachment for $50. Tires, FOBO, some kind of balancing media and some spoons over the next couple of months and I'm in for my first DIY tire change. Was considering Dyna Beads at first, but may give Ride-on a try instead.
I do, however, deeply regret not having purchased 90° valve stems.
#77
For my Harbor Freight motorcycle tire adapter I had a fellow put 1 inch blocks under the wheel clamps. So, I don't use the center stem to go through the tire. But it is useful as a leverage point for the tire rod.
#79
This is a pretty good explanation from another forum:
https://www.bmwlt.com/forums/tires/6...tml#post557475
Plus I have seen what comes out of a tire with dynabeads.
The black stuff was formerly an integral part of a tire...
(not my pics)
The bottom line is you can do what you want with your bike and tire, but they will never be in my scoot's shoes.
(not my pics)
I highly doubt that the source of those photos, can provide internal pictures of the tire, of the tire bead before install and after removal.
Lakerat (08-18-2018)
#80
