New Infotainment for 2019 "Boom Box GTS"
#191
#192
Correct!
2017 and newer only need the tire sensors.
2014-2016 needs also a newer BCM.
A dealer flash is required to activate the feature in BCM and Boom System. And if you have the gauges from CVO models, you can also activate the LED indicator in the gauge (If you have the CVO gauges, you need to check it. The LED indicator is only available on newer version of this gauge. From 2016 and newer)
Photo was taken from my 2015 Street Glide.
System dont shows the tire pressure yet, because i dont installed the sensores now.
guru.v (01-22-2019)
#193
So do I understand correctly that I can add the TPMS to my 2017 SGS by just buying the tire sensors from HD and having the dealer flash the bike to make it operable? Or is a dealer flash needed? This just sounds to simple to not be an add on in the P&A book for the newer bikes??
Thanks
Thanks
Should be able to get them for around $160 for both.
Correct!
#197
I have the Boom GTS from Sven on way. The BCM (41000087e kit (includes BCM 41000341e)) and ECM (41000599) will be here by end of next week. My Technoresearch Centurion Super is updated with 2019 licensing. Let's see.
I've confirmed the 2019 ECM has a different operating system and software level (921). What is the GTS looking for? VIN? I can load a different VIN into this ECM. Fingers crossed....
http://technoresearch.com/index.php/...rion-super-pro
Hi, I received the boombox gts. I connected it without problem to the bike. But when I Turn on ignition, i ve this message on the boombox. I think the boombox is looking for the VIN. Impossible to activate it with Diag4Bike. If somebody has idea of what to do...
#198
Hi, I received the boombox gts. I connected it without problem to the bike. But when I Turn on ignition, i ve this message on the boombox. I think the boombox is looking for the VIN. Impossible to activate it with Diag4Bike. If somebody has idea of what to do...i
#199
Here are my questions about the new system.
1. Will the screen completely black out, with the radio and navigation still on then reappear when you are 2 miles out from your next turn?
2. Will it Bluetooth to my current UCLEAR unit on my helmet and give me Radio, MP3s, Navigation, and be able to talk on my phone?
3. Can it download and flash a new tune into the ECM after I make performance changes to the bike.
4. Can it autotune the bike after I make performance changes for optimal performance.
5. Does it have a camera mounted into the front of the faring so I can record rides onto a SD card, or go on Facebook live so others can see me ride.
6. Can I make a Facebook Video Phone Call to me wife as I am riding, so she can see me.
#200
1. Huh? Never seen that on my 6.5GT - haven't heard of it happening on the GTS (yet).
2. Only if you have the WHiM module installed. If UClear uses standard BT protocols it should pair,...BUT...no stereo sound. (Same with Cardo & Sena)
3/4. You can tune a piano but you can't tune a fish, or an ECM with it.
5. No, but if you buy the Sony XAV AX5000 package from Volunteer Audio it has an input for a back-up camera that you could hook into the wiring of a back-up kit if you installed one.
6. No, but I hear that they're coming out with a GTS-M that features a flip-up faceplate with a mimi-microwave inside.
250starbuck (08-24-2019)
