High-Pitched Whine Suddenly Developed
In what sounds like the primary area. It's VERY pronounced when I downshift to 1st while slowing down. It's loudest in neutral. Reduces some when kicked into gear, but it's DEFINITELY a new sound. And it sounds like $$$. I JUST had a 25,000 mile service done (all fluids, gaskets, etc) a couple of months ago. Did they forget to put fluid in my primary or tranny?
I just dropped a couple of grand on the service (and other things) and this is making me VERY concerned. Any thoughts on what it could be? Oh, the bike performs fine. Shifts normally, etc.
Received 4,281 Likes
Campy Roadie (08-28-2018)
The automatic primary chain adjuster simply ratcheted up a notch and it's tighter than it was before. I've had the same thing happen several times. As the tensioner wears a little and you get a little slack in the chain, it will quiet back down pretty quickly. At least until it hits the next notch. Nothing to worry about.
Edit - had to check the guys profile 2010 Streetglide (?)
