Coughing through Intake
Old 08-28-2018, 04:06 AM
5frost5's Avatar
5frost5
5frost5 is offline
Stage IV
Default Coughing through Intake
I am having an issue that just started out of nowhere on my bike 2007 electra glide classic. It wants to cough back through the intake, so it and sputter and cut off occasionally. I have. K&N open air filter, freedom performance headpipse, and DNT megaphone mufflers. I've checked everything I could think of other than the injectors. I was wandering if anyway has had a similar issue where putting a tune on the bike fixed the problem? I was going to tune it soon but was going to install some cams in it first then tune but didn't want to spend the money on cams and tune if I have an underlying issue.
Old 08-28-2018, 04:12 AM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
99 % of the time it is a lean AFR .
Old 08-28-2018, 10:43 AM
Boomer1143's Avatar
Boomer1143
Boomer1143 is offline
Thumbs up
Check for vacuum leaks, plugged fuel filter, injectors. Engine is not getting enough fuel or it's getting too much air.
Old 08-28-2018, 02:12 PM
ORradtech's Avatar
ORradtech
ORradtech is offline
Sounds like an open filter and a free flowing exhaust without a tune.
Really cannot do stage one af and pipes w/o a tune(r).
OP could always put the stock filter or exhaust back on and see if that makes it better.
Old 08-28-2018, 02:55 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,481 Likes on 1,540 Posts
If you had all those mods before it started acting up and it was running good, i would look for an intake leak. I agree 99% of the time coughing back thru the intake is a lean AFR.
Old 08-28-2018, 03:40 PM
e6fmf's Avatar
e6fmf
e6fmf is offline
Check for intake leak. Using can of ether with straw hose/line. Start bike, using ether, spray towards intake (where it connects at the heads) NOT at the carb opening. If it runs rough that brief period, you have found your leak.
Old 08-28-2018, 07:27 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
iac or tps.
Old 08-28-2018, 08:22 PM
jeeper101's Avatar
jeeper101
jeeper101 is offline
Same issue here and in my case it only happens when the bike has been going for a couple of hrs and it’s hot. I already checked for intake leakes, there are none. I do have a tuner, I suppose I could tweek it a bit and see what happens.
Anyway, hope you find your issue as well OP
Old 08-28-2018, 10:59 PM
Deucedog's Avatar
Deucedog
Deucedog is offline
I had a similar problem a few years ago. It would run okay for a couple of hours and then start 'sneezing' out the air cleaner.
It turned out to be a pin hole in the fuel line inside the tank. As the fuel level went down the 'sneezing' would get worse until
I couldn't get the bike above about 50 mph. (Fuel pressure on EFI bikes needs to be around 50 psi.)
Old 08-29-2018, 07:55 AM
RevBlk's Avatar
RevBlk
RevBlk is offline
Clean the IAC port. I do my 07 twice a year. Does exactly what you are describing.
Quick Reply: Coughing through Intake
