Passenger floor board mounting
Received 14,658 Likes
I don't think the lowest hole on my 04 is thread tapped. That one, as I recall, just held the nub on the bracket that keeps the board flat and level.
If you use other thread holes, you might want to repaint the holes that held bolts before, or that you ever run the bolt through, just to prevent rust from getting started on the exposed steel.
Received 47,790 Likes
Got a thread tap? Wouldn't be overly hard to tap it yourself. Even if you have to buy a thread tap at the hardware store, they aren't expensive.
