Experiment Results; Ran out of gas, ON PURPOSE !
#31
Received 2,858 Likes
This reminds me of old days on a metric where you ran it out of gas, reach down and flip the lever over to reserve while on the fly, ride on and get gas when you can as you cut the fuel off and empty the settling bowl that usually had water or trash in it.
Ah, the old simple days.
#33
Tony P (09-27-2018)
#35
1) the fuel pump is not submerged when the tank gets below 1/2 full. The pick up "sock" is literally at the bottom of the tank. The fuel pump does not care if it's submerged 100% of the time.
2) the pickup tube is a "sock filter" and it will keep even the finest materials out of the fuel pump.
3) when the fuel pump can no longer pick up fuel (because it's empty) the fuel remaining in the lines can no longer be pressurized so it is not expelled. Thus, the fuel injectors are not run dry.
grbrown (09-28-2018)
#36
From post #1:
