Stone through drive belt advice
I hate to split straws....but you don't have the "same exact issue".....
Your belt is compromised near the edge, his is almost dead center.... That is a big difference... With the belt cut near the edge, there is a higher probability that your damage will migrate to the edge, causing a tear/split/break of the belt...
It's kind of like a tire.... shops will plug/patch a tire as long as the hole is in the center of the tread. If it's near the shoulder of the tire or in the sidewall.... they won't touch it...
If you're not riding hard, I believe you probably could make your trip on that belt..... but if it was me, I'd replace your belt sooner, rather than later....!
PS- Look at the last pic in post #1... that page from the manual says you should replace your belt...
Campy Roadie (10-16-2018)
Two observations to make here. One is I agree with hattitude that your wound is not the same. Being near the edge of the belt like that, rather than close to the centre, you are on borrowed time as the belt is more likely to give way on that edge. You also seem to have the offending item still stuck in the belt, which is not wise IMHO. Second comment is you have damage on the back of the belt, as if it has been rubbing against something. That also needs to be investigated and sorted out, before replacement. A gentle 700 miles may be quite practical, but a new belt pdq would be very sensible!
As mentioned, you have it closer to the edge , and a bigger stone// damage, than what I had... Re your ride, it is a bit like,, "your dammed if you do,, or your dammed if you don't "....
I did go for my 2000km ride last weekend with my stone damaged belt, (see first post) .. There was no change to the damaged area . In actual fact , it was hard to see the damaged area when I checked it on the ride.
I have the new belt and parts for the change over,, but have decided to replace belt next tire change , which is in approx 5000km if there is no change to belt damage...
Back to your predicament ,,, I would get the stone out .. Then check if there is any damage closer to the edge.. Looks like it will be at the limits of what it says in manual....
On a side note,,, there seems to be some chafing along the top side edge of belt , (below stone damage)… Just seems out of place....
Looks like its your call , unless you can replace belt before the weekend .. If it does your head in thinking about it,, just remember , there will be other rides and weekends away.....
By contrast a friend bought a new Buell Firebolt when they were first introduced, rode it 30 miles home from the dealer and promptly took those ugly (expletives deleted) guards off. Later the same day he rode the few miles over to show it off - and had picked up a large stone that pierced his belt. All on the day he bought his bike!
