Thinking of a cam
Thinking of a cam
I will be having my 2012 Ultra in the shop this winter for unrelated items and was wondering what I'd see from installing a stage 2 package. I already have the pipes and breather installed and was thinking of having a cam put in while it's there. I haven't been real happy with just the two upgrades and was hoping someone might enlighten me on the benefits of this install.
Also planning a trip West for next summer, is a cam going to help with the long wide open roads ? It's going to be a long winter.
Thanks
Thanks
you're opening up a never ending can of worms. The debate over cams never ends. Here you're going to get a lot of "opinions" from self proclaimed experts. And here's one more. Your best bet is to have an in depth conversation with whomever is going to do the install. Discuss what your realistic expectations are. Then see if you agree and interested in that suggestion.
Some people make the mistake of chasing numbers and overcamming their bikes. For example, a local shop here in the Carolina's insist on putting Woods 777's on every bike. When I asked why, the reply was, because that's what we do. I'm sorry but that's like having a conversation with an infant. There's no logic to that answer. The Woods 777 is a great cam but to much cam on a stock 103 engine without bumping up the compression.
Anyway, good luck with your search.
It would be easy to spend an eternity working through the countless options available! For some of us that will be part of the hobby, however if you would prefer a short cut, that's why I suggest above contacting one of the experts we have easy access to.
Thanks
Thanks
Educate yourself a little more by reading posts (there are tons), then ask questions.
OP: Graham has given you the best suggestion you're going to get, and he even named the guys to talk to. They're all very good, and very helpful. They'll probe you before making suggestions which will be based on how you ride and where you want your motor to be making its peak power. For a stock 103" there are MANY cams that perform exceptionally well and that make peak power in different areas of the torque curve. The guys that Graham mentioned will have experience with most of the many that you could choose from. Call them and let them pick your brain a little....you won't regret it.
Thanks
Thanks
