Rear Shocks - 2019 CVO SG
Picked up my 2019 CVO SG couple of weeks ago and while I love the bike overall, I can't stand the rear suspension. It seems to ride like a rock. According to the chart that came with the bike, my shocks should be set to around 7 or 8. At this setting it's brutal. I currently have the rear shocks adjusted to 3. It seems better, but still hard, compared to my previous 2016 Limited. At some point I will probably change the shocks to either Progressive or Legend. I have three questions: 1) Is it really worth the money for new shocks to improve the ride? 2) If I put on 13" shocks (as everyone seems to do) how does doing so affect the steering geometry and handling? 3) Does the drive belt need to be adjusted by changing the shock size by 1" ?
A tip I would like to pass on is that if you ride mostly solo then the choice available, which will give decent results, is now numerous enough to make selecting one a bit of a challenge. If however your Mrs B likes to ride along then the rules change and IMHO only few options will work really well - although that does make selection easier! The reason is that the extra weight of a passenger pushes some brands beyond their comfort zone, also the passenger is sitting directly over the rear shocks and gets a quite different riding experience, compared with the rider up front, so has higher expectations of ride quality. Unfortunately too many members who comment on ride quality of their preferred brand don't say if they ride solo or duo. My Mrs B loves our Ohlins - they have transformed her riding experience!
You have a new and expensive bike and it is reasonable that you to expect it to come with super suspension. The fact that it doesn't is shameful, but don't make the mistake of buying cheap replacements - do the job properly and be amazed! You can always remove your new suspension before you sell or trade your bike.
Thanks for the input.
I ride solo 100% and only carry a T-Bag for maybe two trips per year to HOG rallies.
I have my preload adjusted down to 2 on the stock 12" Premium shocks even though the book recommends around a 7 for my weight (220). Doesn't having the preload adjusted down to that level increase the chances of bottoming out? I think a some of the issue stems from the fact that the CVO SG has 19 & 18 inch low profile tires compared to 17 & 16 inchers on my previous 2016 Ultra Limited. Better handling at the cost of ride comfort.
So far, I am leaning towards either the Progressive 944's or the Legend Revo A at some point in the future. Any thoughts?
The book settings for a particular weight makes for very rough ride, so being at a “2” might work, but seems low for your weight? What you’re really seeing is the difference between a 13” shock (on your Limited) versus a 12” shock you have now. If you get a quality 13” shock, you’ll have a much better ride. Yes....the bike will sit a little higher unloaded, but will be sitting at the normal height once you sit on the bike.
Tons of threads on brands of shocks here, just do a search and you’ll find tons of information. I’m partial to the Pro Action shocks with the warranty (lifetime) and ease of adjustment. Ohlins is a strong player here on the forums. Legends are also warranted for life as well.
Get a 13” shock on that Street Glide and you’ll be more than happy. Good luck with your choice on brands!
bo54gey (11-18-2018)
Received 2,523 Likes
I have Ohlins, front and rear -- it is transformative. I see you are on LI -- so am I . You want to give my bike a try? We can do that. But be warned, you are then in for a $2500 upgrade which you will have to have. But what is a new CVO? is it up to 40 grand? Hah -- top shelf suspension is a mere bag o shells..........
My shocks would not move regardless of the setting. I took a saddlebag off and put my foot on the bar and no matter how much effort I could get no movement including sitting on the seat and bouncing with all my 200 lb weight. Just bite the bullet and replace them. After mine hurt my back badly twice hitting some dips they got replaced immediately after. The shocks Harley put on these bikes are pure garbage. My bike now rides better than a Goldwing I use to own with the cheaper $600 Ohlins. I'm sure the more expensive ones are even better but I didn't want to have to fool with rebound settings. Shame Harley puts the same garbage on $40k bikes.
