Road King is HOT
My '09 RKC is 103ci Stage II with Rinehart slip-ons and ACR's It's been dyno tuned twice. Has well over 65.000 miles on it. Runs great. But it does get hot in stop and start. I installed mid frame air deflectors and that helped a lot. HD's touring bikes have a heat problem. That's no secret. The problem can be reduced somewhat by richening the fuel on the low end. But not a whole lot.
I did put the FP3 on it and it did seem much better last night, but have to do a better test during the day to see how much it really helped.
In order for these bikes to pass EPA emissions testing the AFR (air to fuel ratio) at all speeds had to be increased. In other words run lean. Any engine that runs lean will run at a higher temperature because the fuel burns much faster in the presence of so much oxygen. Plus any carbon monoxide left over will ignite in the exhaust and generate even more heat. Add in higher engine displacements. Free flowing air intakes. Add in the weight of a touring bike and heat is the result. Some improvements can be made by using tuning software to richen up the AFR. But there's only so much that can be done using just ambient air to cool things down. Thus the intro to liquid cooling, fans and more valves.
Wanted to pop in and provide an update. Loaded the FP3 tune ( was surprised to see Python slip one as an option, guess Vance and Hines makes them?) and went on the same route where I noticed it was real hot in my initial post.
Still pretty hot, but seems to have helped quite a bit. The rear cylinder never cut out this time so I'd reckon it's helped. More rides will help solidify that feedback, but so far so good:
