Paint peeling inside fuel tank. ‘03 RK
I fueled up today and notice a gray colored flake (paint or sealer) peeling off from inside the tank. I was able to reach in and take it out with my fingers. Anyone have this before. Sounds like a problem if i need to remove my tank and clean it all out. I’m thinking I’ll just let it be for a while and see what happens.
Any ideas?
Any ideas?
There are sealer kits you can use to clean, prep and re-seal your tank. I've used Kreem in the past. I've also heard there are better products but I don't recall the name. It's not difficult, but a 5 gallon tank can get heavy when you're swishing around a couple of gallons of water/solution. The flaking will block your fuel flow eventually.
https://www.amazon.com/KREEM-Gas-Tan.../dp/B00IKKQ2U4
Bare steel works just fine. That's why almost all gas tanks are bare steel. They flash rust, and rarely anything more. Even with ethanol fuels.
Various gas tank sealers exist to solve a non-problem of catastrophic rust, and in fact often create problems, by their flaking and peeling. Older ones and a number still on the market do not withstand ethanol fuels.
Kreem was quite the money maker for us at the shop. Customers would line their tanks with it, then their bikes wouldn't run as it flaked off. We'd do a semi-expensive removal of the liner, and a rebuilding of the carburetors. Sometimes even a carburetor replacement, and or gas tank replacement, depending on the ability or inability of us to get the Kreem particles out of the carburetor passages and off the tank walls.
The following 2 users liked this post by foxtrapper:
Dehammer (01-29-2019),
FLRoadKing (11-20-2018)
Your idea of bare steel sounds good.
I had the tank lining peel in a 2001 Springer I bought about 18 months ago. It had only 9.8K miles, and had sat for a long time. There was a ton of peeled liner in the tank, along with some light surface rust.
While researching the various liner replacements, they all had at least one report of re-peeling. I also read many who said not to worry about bare steel in the tank.
It was a carb bike, so I only had two small fill/sending unit holes to work with. I removed as many big pieces as I could. I then put a bunch of very small (I forget the gauge) shot in the tank. I would probably use the pea gravel this time, as it probably would have better scrubbing action. I sealed up the openings, wrapped it well in bubble wrap, and then some big blankets, and put it in the dryer. Once satisfied it was wedged in there well, I tumbled it without heat.
I cleaned out the shot, many pulverized liner pieces, and rinsed it well... the tumbling had removed the vast majority of any liner left in the tank. It even seemed to "scrub" some of the rust.
Here is what I chose to do rather than re-coat the tank. I filled/soaked it with diluted phosphoric acid to neutralize the rust. I drained, rinsed, and neutralized the acid with baking soda/water, rinsed with alcohol, then dried completely. After all that, I just left the tank bare steel....
I have not had any issues with the tank since. I do, however, keep the tank full most of the time ...
crazytown (11-21-2018)
