Lift Table Width ?
#31
My Handy Lift is 29 1/2" wide for the lift table and it has two add on wings that make it 39 3/4". I don't have any trouble riding up onto or off of the table without the wings and didn't install them initially because I have a small garage. My floor isn't completely level so every tool I put on the lift table rolled off. I installed the wings and now I have a nice place for the tools I'm using on both sides.
One other thing I'd like note. I have a standard wheel vice on my lift that has a crank and I work alone 99% of the time. The key to putting a bike on the lift by yourself is to measure the front tire width and open the vise to just that or a little smaller (now I just know how far apart to have them). Ride the bike up until the front wheel is all the way forward in the vise, kill it in gear and step off to the left holding the left handlebar. Crank the wheel vise tight and then attach the tie downs you already had laying on the deck. Reverse the process to remove.
ROCKOUT Rocker Products (01-19-2019)
#32
I'm looking for a decent quality lift as well.
Would like the ability to have the extensions so I could also use it for my snowmobiles, riding mower, atv's.
I'm almost 64 and love doing my own work, but crawling around on the floor is starting to get hard (actually getting back up is my short coming).
Looked at HF but would like something a bit more substantial.
#33
If that is a bit more than you want to spend, you might also look at the APlus Lift. That is the one I was leaning towards till I found the HMC.
#34
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Campy Roadie (01-19-2019)
#35
#36
#37
I bought a Direct lift from a custom bike shop going out of business for $400.00. It looked like a bike had never been on it. I work alone most times so I picked up some side extensions in Ft Meyers for $200.00. Had to drive down and pick them up I also bought a Titan wheel chock that I can just ride on and get off the bike with no assistance. Went to Home Depot for some non slip stick on grit for better traction for the rear wheel. I'll be 72 in a couple months and can no longer handle the top heavy dressers like I used to. For me the side panels are a place to keep tools ect. close at hand and a little less cluttered. I have a roll around stool with adjustable height to sit on when my back takes a ****. My 50" Kubota mower fits on there just fine too. I will say if the Direct lift had not been such a buy, most likely a Handy lift would be in my shop right now. Like most here the lift table just makes the now impossible task of working on bikes for an old guy possible again. I also have a J&S jack for wheel, brakes and whatever much easier. I hope there is some info here to help others.
#38
On both softails, is not an issue for me. I can stop while driving onto the lift, anywhere along the ramp, and my feet can touch the ground
When riding my Ultra Classic up the ramp it's different. If I had to stop, for whatever reason, when the front tire is on the lift and the rear tire is on the ramp.... I would only be able to reach ground with one foot on my toes.... there's a real good chance the bike could tip over...
The results of my bike falling over at that point, would cause some pretty expensive damage. The ramps aren't cheap, but they were worth it to avoid that scenario...
It's been mentioned several times, and I'll repeat it.... Given the chance, I would sink my lift into the floor. My shop contractor offered to do it when I built my small shop, but I wasn't sure which lift I was going to use (dimensions) or exactly how I was going to arrange the shop. It would be sooo much better in sooo many ways to have the lift flush with the floor when in it's lowest position!
I'm still toying with sinking my lift. Unfortunately, I don't have the "concrete work" gene, and have yet to find someone willing to do the job...
#39
The uses that interest me, are for my Street Glide, Snowmobiles, and lawn mowers.
Thinking that a quick mount to attach my Condor to the table rather than a vise might work better? Bad or Good idea?
Also can anyone point me towards a lift that has 2-piece per side (split) extensions? For sleds leave the front ski sections on and remove the rears for better access to track and suspension work.
Not ever lifting over a 1000 lbs but wondering if the 1500lb versions are overall much sturdier?
The lifts with a dove tail would make loading easier but look like they would be in the way while in use. It would be easy enough to build a separate approach , Bad or Good idea?
Thinking about it.....it wouldn't be too difficult to split and support a single extension if desired.
Thanks
Thanks
#40
Thanks
Thanks
Bodacious MC (01-23-2019)
