ACR's and clean up.
#31
#32
I did the head swap with 103 heads with the ACR's on my 2010 when I did the motor. I didn't want to mess with sticking my hand on a hot head every time I wanted to start it.
I went all out on my motor, heads, cams, big bore. I sold the 48's that I had in it before. The dyno showed 126tq 116hp. Shop said I could pick up a few more with a different exhaust (D&D is what they wanted me to go with). The bike is a bast to ride and I haven't had any issues with durability with the bottom end. I did install an AIM VPC clutch when I did it. If you are going that far why not go all the way? The shop that did it does a lot of builds like mine and said that they have seen as many stock bikes with crank issues as they have motors that are built up. They also said that they have not seen many that had shifted in either configuration.
#33
I got a while to wait for the weather to be hot enough to cause a hot start issue. I’ll think about my options for a bit...
You got me thinking back to what I talked myself out of last year. FM 107 with 555’s was my thought before doing cams only.
#35
Im just ready for a run on the Dyno and don’t want to do it until I’m confident I can leave it alone for a couple years.
#37
Received 47,784 Likes
#38
#39
The following 2 users liked this post by Campy Roadie:
LQQK_OUT (01-13-2019),
Uncle Larry (01-13-2019)
#40
I hate when a post is written in a such a way that it makes me think of course I need to go all the way.
