New Drive Belt Questions
After 52,000 miles I caught a rock that put a hole in my drive belt.
I'm not sure how long ago it happened since the belt is still in one piece, but I'm getting it replaced.
Can someone recommend the parts to replace at this opportunity with the primary opened up?
Obviously, we'll evaluate the compensator, chain adjuster, stator, etc.
The clutch disks would require a bit of extra work to inspect and therefore result in replacement either way.
With this many miles (I'm not hard on clutches), would you change the clutch parts without question?
Is there anything else? Swing arm bushings, perhaps?
Thanks!
Thanks!
jberg (01-09-2019)
jberg (01-09-2019)
The following 2 users liked this post by skootchnc:
jberg (01-09-2019),
Kingglide549 (01-07-2019)
My clutch looked brand new at 32k when I had to replace alternator rotor due to splines. I measured disk and steels using the non wear area as a reference. The clutch in oil does not wear if you use it properly and drive like you have some sense..(ha..like you can get killed on one of these things) If you are paying someone, replace it.
Harley recommends pulleys with belt. For sure make sure there is hard chrome on rear aluminum one. (A steel scribe will cut into aluminum if chrome is gone) Check profile on front.
jberg (01-09-2019)
