Write a couple of more pages of posts but the best answer is ADJUST YOUR CLUTCH. For most of you that means have someone competent adjust your clutch.
Ok so the shifter pawls arent adjustable on the newer bikes, and most newer bikes have hydraulic clutches with no adjustment...
Your simple answer leaves out a lot of bikes on the road right now. With my 16 RGS, neutral was so damn finicky when new. I figured it would wear itself in and it has to a point but thats also coupled with flushing the clutch fluid and making sure it was bled completely.
If you have a hard time getting into neutral, adjust your clutch (the proper way) and be done with it.
I guess I've wrongly assumed HD has it adjusted? I haven't adjusted it yet since new. Stage IV, they were in it. 2018 hydraulic clutch, and I do have a manual, time for some reading.
I'm new to HD's, and the '15 UL I just purchased isn't too bad (3900 miles on it), but it's certainly more difficult than the Yamaha Roadliner I've had for 13 years. I'm sure some of it is just familiarity. However, I test rode 2 other '15 UL's, and they were both much more difficult (15k and 25k on the clocks). At one point, even my wife noticed how many long it was taking to find neutral.
You missed my post above yours obviously, you cant adjust the hydro clutches like you could the cable setups.
This is why pjbs simple advice does people with new bikes no good at all.
The King and I are growing old together and just like me, it gets a bit cantankerous at times. I've found that if I just put a little pressure on the shift lever and give just a tiny tweak on the throttle, it falls right into neutral very easily. Not a big rev like a kid pissing off his neighbors, just a tiny tweak on the throttle.
I remember on my British built Royal Enfield circa 1962, it had a neutral finder. A little extra pedal on the transmission that when you stepped on it, it instantly went into neutral from any gear. Handy, sometimes. Like panic stop when you're still in maybe 4th when you stop, and it REALLY doesn't wnat to work through the gears down to neutral while you're standing still.
Primary oil makes a difference. My 06 FX finds neutral with anthing in it. My 09 Heritage is picky. After putting in a screaming eagle clutch pack and changing to spectro primary, neutral was impossible. After many clutch adjustments And no help I switched to HD Formula I. Better but no cigar. Finally I switched back to Rotella which I used for years successfully and the problem is completely solved. Neutral is now a breeze. Oil does make a difference.
Amsoil 20w50 in the primary and amsoil 75x140 in the trans. The neutral problem is sometimes caused by clutch plates sticking together when sitting unused for longer periods, Colder temps can cause problems too. I had a similar problem with my '15 after it sat for over a yr while I was going through some physical issues. 150 miles later the clutch issue has pretty much been solved .Hope this helps.
