Why all the apparent problems finding neutral?
Old Feb 2, 2019 | 05:47 PM
  #51
Redlegvzv's Avatar
Redlegvzv
No problem finding neutral on my 2018 Road King.
Old Feb 3, 2019 | 12:08 PM
  #52
JakeC7R's Avatar
JakeC7R
Anyone ever tell you that you look like Kevin the MC Rider guy?
Old Feb 3, 2019 | 02:48 PM
  #53
FastHoss's Avatar
FastHoss
If you have the right amount of oil and adjustment is done right and still can't hit neutral hot what you have is a worn clutch cable. Those cables wear out pretty quick. Even though they don't look like it.
Old Feb 4, 2019 | 06:56 AM
  #54
Crabchuck's Avatar
Crabchuck
Originally Posted by pjb
you can't see how the primary chain is related to the clutch/transmission?????
I see how it's connected, but once the clutch is disengaged, the input shaft of the transmission is essentially disconnected with the exception of the hydraulic drag. So how does a primary chain being "too tight" cause difficulty getting into neutral??
Old Feb 4, 2019 | 05:20 PM
  #55
TSheff's Avatar
TSheff
Primary out of adjustment does not allow proper disengage. Like a really Hot women still being bitchy sometimes - It is just the way it is.
Old Feb 4, 2019 | 07:06 PM
  #56
Gary1's Avatar
Gary1
Red line helped my 2018.
Old Feb 4, 2019 | 07:29 PM
  #57
tnriverluver's Avatar
tnriverluver
About 7,000 miles on mine and it has a mind of it's own. First of nearly 50 bikes I've owned that is difficult to get into neutral. I am going to try Redline next oil change as several friends have told me it worked for them.
Old Feb 5, 2019 | 07:32 AM
  #58
Crabchuck's Avatar
Crabchuck
I think if the chain was tight enough to cause the basket to bind on the shaft, getting into neutral would be the least of your worries.
Old Feb 5, 2019 | 08:34 AM
  #59
TSheff's Avatar
TSheff
OK. I don't have clutch issues and keep mine adjusted properly. You're welcome to do what you wish.
Old Feb 6, 2019 | 08:45 AM
  #60
Crabchuck's Avatar
Crabchuck
I don't think the problem finding neutral is really clutch related. If you had too much oil in your primary, then the drag could cause load friction in the trans. Based on my own experience, it was all just stickiness in the trans (I had issues shifting past neutral with the engine off too).
