Only Starts in Neutral
I understand it's a safety thing, but Harleys didn't have them for years. Then people what happened got stupid?
I someone doesn't know NOT to start the bike in gear without pulling in the clutch first maybe they shouldn't be riding.
I understand **** happens, but it's something you'll only do once.
Bypass the damn thing.
Just sayin'
Just sayin'
It very well could be the left switch-pack, probably is, but... if everything else is working normally, before you replace the switch pack, just give the clutch lever switch a look.
When you pull in the clutch lever you can see it (see below), if it gets stuck in or hangs up and doesn't pop out, like in the picture below, then your bike doesn't know the clutch lever is pulled in. It takes a minute to check. The clutch lever keeps it pressed in until you pull in on the clutch lever, then the cam on the lever rotates and releases the button, and it extends out like in the picture. I had a bike awhile back that this switch had gotten stuck on. May not be your issue, but easy to eliminate as a potential one.
I don't have a Rushmore or canbus. Just rigging the switch so it shows the clutch lever ALWAYS PULLED IN makes the system go nuts? Perhaps I don't want a new bike as much as I thought I did.
Certainly get it replaced at the dealer if your ESP will cover it (with a surcharge to you?). But I wouldn't say the WD40 trick is just a temp fix. Mine (a '17) acted up in the first season. I lubricated it and it hasn't done so since (now at about 29,000 Km). Of course it gets lubricated when checking everything at each service. Your bike is 4 years old so it might just want a little lubrication if it hasn't been done.
TwiZted Biker (03-14-2019)
To the OP, there is a clutch interlock switch in the housing, works similar to the brake lamp switch on the other side. Follow this for a test:
Ride safe!
This happened on my '09.
There are no safety switches on neutral, clutch, or kick stand.
One day it wouldn't crank until I put it in neutral.
It happens only intermittently now but at least I know that finding neutral is the remedy.
I do understand that one should usually start in neutral but, as said earlier, you might stall in traffic and need a quick start.
The real puzzle for me is that there never was any safety mechanism for starting, now it seems to have developed one on its own...
